Installing the rudder pedals was just cleaning up the pivot blocks and then drilling the 3/8" holes in the NG30 middle plates in the right spot.
The pedals were pre made in New Zealand by another builder who did a great job for me. There is still a lot to do on these. I'll set the pedal position heights after the wings and on and things hooked up so I can then position the brake cylinders exactly right for my leg length. There is adjustment but while I'm impatience to do it now it will be better later.
There is still the little .25"OD steel spacers to put in. I bought the right rob from Spruce but what they sent was the wrong OD and will not allow an AN3 bolt. Next order.....
I have to work out how to connect these to the rear pedals and do that install. For now its another step forward....pardon the pun.
