Cutting foam is getting easier using an extra long jigsaw blade. It took a bit of thought to get the right size foam pieces.
Fitting them is tricky due to the angles required. If the foam is forced into position NG31 will distort. I made the right side a touch short and later microed a 1/8" sliver on the end. Fit is not critical according to the plans.
Nice to see the fuselage looking a little bit bigger.
