Daves Web Site
Date:  5-4-2013
Number of Hours:  10.00
Manual Reference:  9-2
Brief Description:  Main Gear Tabs V3 Tab shaping
Pic 1 has the holes drilled using the same technique as shown previously. Some hours went by as the tabs took shape again for the third time. It was nice to see the tubes still fitted with very little sanding required to open up the holes as you can see in the third pic.
Rough outline of tabs
Tabs shaped
Tabs shaped
The tubes still fit
The tubes still fit
