Daves Web Site
Date:  12-22-2012
Number of Hours:  10.00
Manual Reference:  9-1
Brief Description:  Brake Cutout final prep
This was over a few days. First job was to micro in LB23. I first rechecked that the cutout was deep enough and that I had allowed for 5 layers of glass (three in the front, two over the back) and the brake would still fit the depression. i.e. it would move back 1/16" or so once glassed in place. I used a lit of metal as you can see in the first pic as a spacer. I probably left too much space to be sure.
Next step was to micro in LB23. I decided to do this with wet micro and let it cure. Then I added dry micro on the edges and all around the brake to ensure smooth transitions later. I'll have a little filling to do on the brake edge as in pic 1 and where I've made joggles.
Pic 3 is preping the area for the layup. I'll be wet cutting the glass to the inside of the blue tape later. This took quite a while and I had to remove a lot of micro to ensure the hinge would sit flush. I really really wanted to be sure I didn't have a brake sitting proud of the fuselage and sideways to the center line of the plane. Quite some hours had gone into this quite small job.
Checking brake fit
Checking brake fit
LB23 microed in place
All ready to lay up
All ready to lay up
