Brief Description: Add F28 bulkhead and support blocks
Adding F28 Bulkhead is 5.9" from the front of F22 and was better left until now. The bulkhead was carefully fitted and then two small spruce supports were made from left over longeron timber.
The parts were simply floxed in place after pre sanding the already peel plyed areas and lightly clamped.
Taking a few of the main clamps off it was easy to see the movement off the centreline than can be easily achieved. The floor will lock things into place and will need careful positioning to maintain all the alignment work done so far.
