Daves Web Site
Date:  6-16-2012
Number of Hours:  10.00
Manual Reference:  6-1
Brief Description:  Preparing Bulkheads
Each bulkhead, F22, Instrument Panel, Ft seat Bk seat and firewall all needed to be fitted to the sides. Particularly the firewall as this captures the longerons at 6 places and needs to be correct.
Careful sanding of the foam edges for a close fit. I made a channel for straws which will be the lightweight conduct for the nylaflow covered rudder cables. As these will go under the upper longerons, allowance is required at this stage.
Fitting F22
Fitting F22
Straws for rudder cables
Front seat fit
Front seat fit
