Brief Description: Triangluar Pieces to lower longeron
This step is making a triangular piece of spruce to mirror a section of the lower longeron so that a box area can be formed next for the landing gear mounts.
First shaped a box length of spruce to a triangular shape and then cut notches as done on the lower longeron so that it would bend and fit without too much tension.
Then a trial fit as it is an awkward shape. Alternating clamps, side then top, worked well. I didn't bother with nails this time.
Then flox both sides into place, clean up and leave to cure.
