Daves Web Site
Date:  12-24-2011
Number of Hours:  10.00
Manual Reference:  4-2
Brief Description:  F22 Aft face
F22 prep then aft face with 2 ply of BID and doubler pressed into place while wet. Then further plys per plans locally over the doubler. Lower edge transitions were peel plyed.
I used weights for the cure. Probably not necessary. There is a concern about warping but this is often when external heat is applied and my room was hot enough at 27C.
F22 prep and IP prep
F22 with doubler
F22 with doubler
F22 during cure with weights
