Brief Description: Added oil access door to top cowling
Added the oil test access door to the top cowling. Deviated from the plans by fabricating an aluminum backing plate and cutting out the fiberglass mounting flange. I did this to make a much better fit of the door to the cowling surface than could be accomplished if mounted directly to the fibergalss flange per the plans. The door sits flush with the cowling surface.
