More equipment installations prior to tailcone closeout. I started with the fuse block first. Basically what I did was to replicate a bracket similar to the ELT mount out of scrap that I subsequently drilled and riveted to the j-stringers. The ELT itself simply strapped onto the mount. The antenna cable turned out to be a problematic. First, with Toni's help, I riveted on the ELT antenna doubler. Then I routed the antenna cable that came with the unit and discovered I had made an error in locating the ELT's loaction from the antenna. I had measured to the aft end of the ELT adn used that to fioanalze the locating for the ELTback. The problem is the ELT connector is on the front of the unit so the cable ended up being too short once everything was installed. It's easier to replace the cable then to move the other components, soooo, I got my frist opportunity to fabircate my own RG400 antenna cable.
