Temp installed the landing gear weldments in order to match drill the forward braces and side flanges. It was a bit of wrestling match to get them installed, but the match drilling was completed without a problem. I did have an issue trying to take them back off and ruined a couple of bolts in the process and had to order replacements (plus a few extra to have on hand). I also decided to buy a new ratcheting wrench becuase access to the nuts in between the forward and aft center section bulkheads is severly limited and a normal ratchet won't fit and regular crestent wrench is a royal pain as well due to limited throw space (you have to move then reposition the wrench many times just to get one complete turn of the nut).
