Bruces S-19 Build Log
Date:  10-1-2010
Number of Hours:  6.00
Brief Description:  preparing the center fuselage for joining
Spent a few after work days finishing some odd jobs prior to starting the fuselage join. I decided to not do anything about the rivet hole thur the rib into the bulkhead flange that falls on the edge of the flange. There will be a gap between parts under the rivet and a notch in the flange, but I don't think it will be a problem. Reamed the bolts thru the landing gear block.
Form block for bending a radius in  baggage bulkhead flange
This hole c/t the baggage bulkhead falls on the edge of the flange
Reaming the landing gear block
