Bruces S-19 Build Log
Date:  4-13-2013
Number of Hours:  0.10
Brief Description:  What to do with the sealant tube nozzel thingie
What do you do with the cured bit of sealant that forms in the nozzle of the tube when it hasnt been used in awhile? It turns out it makes a great holder for a tube when you need to cut or polish it. Inserted in the end of the tube it provides a means for holding the end and keeping the tube from spinning.
This was pulled from the nozzel
great holder for cutting tubes
easy to hold small bushings while grinding square
