Bruces S-19 Build Log
S-19 Venterra
Horiz Stabilator
8-1-2009
Hinge pin fab and deburing
Fabricated the trim tab hinge pins, drilled the holes in the horizontal rear spar for the lock wire retention, Continued dissasembly and deburring. I used a hinge pin bending jig I made as described in the tips section.
S-19 Venterra Home
1984
Aft Fuselage
Aileron
Assembly
Builder
Center Fuselage
Cowling
Demo Flight
Distractions
Fiberglass Tip for V
Flaps
Flight Test
Forward Fuselage
FWF
Horiz Stabilator
Instruments
Interiour
Project
Seats
Shop
Tips
Trim Tab
Vertical Stablizer
440
