Decided to hang the oil cooler under the gearbox and worked up require brackets. The cooler is supported in the orriginal kit rubber cushoned frame. its supported on the top with angle brackets connected to the engine (unused) forward crankcase mount bolt holes. and prevented from rotation by struts connected to the gearbox. Cut a hole in the cowl for the new air inlet.
