Bruces S-19 Build Log
Date:  3-2-2018
Number of Hours:  1.00
Brief Description:  Balancing the stabilator
After pouring the aileron balance weights, I balanced the stabilator. I placed the stab on its hinge pins with the trim tab and drive rod attached. installed the weight and then slowly melted off the excess lead at the aft end of the weight (to maximize amount of lead removed) with a propane tourch, untill the stabilator was balanced on its hinge line.
aileron weights boiling in the mould
resulting control system weights
balancing the stabilator
