Brief Description: Built a wing tip Nav/Strobe light bracket
Built a bracket for supporting the tip light on the non-reinforced plastic tip rib. Formed the bracket using steves Harbor Freight brake over a 3/8' wood dowl pin. Match drilled to the light attachment bracket and rib. I made the bracket from 0.25 6061-T6. I am using Aeroleds Pulsar NAV/Strobe/Position lights.
