Home of the Spodplane
Date:  7-25-2014
Number of Hours:  3.00
Brief Description:  Glassing the sides. Preparation
Cut all remaining cloth and top plastic.
The diagram is how I plan the layup. I had problems in the past where I cut all the cloth to fit, but because it isn't oriented correctly doesn't fit. Or I get it backwards, etc. Bit like the Oirishman that finds a really good fishing spot, so puts a mark on the side of the boat so he can find it again... This way I have a mark on the exposed end of the rolled-up cloth which I can line up with a feature on the aeroplane, and I mark it on the diagram so I don't forget. All the cloth is stacked so the next layer is topmost, and the reference mark is a number so I can check if the layup schedule is going as planned.
Going to work with a sore throat, irritation from some food I aspirated last night (on the console, "JST123, COFF COFF, descend to COFF COFF..etc.)
cutting, cutting
cutting, cutting
Method for orienting the bits.
Copyright © 2001-2021 Matronics. All Rights Reserved.
