All cooled down and looking not too abnormal today. Other than the foam wedges the Wing and Winglet foam does not seem to have been affected. The wedges appear to have expanded a bit in the heat and forced some of the flox out in lumps. Probed around and couldn't find any voids. Span wise there is a 1mm out of level on the upper surface of the right wing, which may have been there before, everything else is straight.
Made everthing flat with the multitool and dremel die grinder bit, (minding the BID), and it all looks better, leaving some divots and gaps that will flox up before Layup #2.
