1. Traced down a stray voltage. Turned out to ber caused by the terminals of two circuit breakers touching. Installed an insulating wall between the two circuit breakers. 2.Made land installed thel cable from the firewall power to the starter contactor. 3. Installed the starter contactor start wire. 4..Installed the ground wire for the prop heat.
