Brief Description: Tested Trim System, ELT Batteries installed. Prep
Tested Trim System, Roll trim is correct. Pitch trim needed motor wires reversed, so swapped out the pins for correct motor direction. All tests good. ELT Batteries installed. Prepped documentation for comm stack wiring.
