Canopy Seal pics. Installed earlier this week, but wanted to document for others. Concept here is that without these pieces it is hard to create a seal to keep out water and elements from the boot cowl area. This allows you to create a good Proseal fillet in that area and close up the gaps. I also fabricated small .025 angle clips that will seal the flange scallop/openings that can allow moisture to enter the boot cowl and compromise avionics. Will install that later when I rivet on this last skin.
