Seat Heat Finally Finished: seat connectors completed, control switch wiring completed. Switches ran to fuse bus and forest of tabs and onto seat heat harnesses. Tested seat heat pin outs and relays. Found that Left High relay was not activating. Troubleshot that and found improperly crimped Amp pin. Redid and all works fine. Done!!!!
