Brief Description: Lower Cowl fitted, trimmed and drilled to firewall
Lower Cowl fitted, trimmed and drilled to firewall perimeter. Top sides measured with laser to determine appopriate cut line. With the cowling there is absolutely no way to actually trim it so that it is level with the forward split line. So used the laser to draw an appropriate even line for trim. Bottom right cowl looks terrific. Bottom left - not so much. That will need an entire edge added of 1/4" in spots.
