Brief Description: Engine Ground Strap fabricated. Field wire at reg
Engine Ground Strap fabricated. A note about the ground strap. If you look carefully you will see a loose fitting adel clamp that helps to route the ground strap. This is there as if left unsupported it MAY contact the right mag P-lead. That would be very, very bad as it would ground the magneto and turn it off. I will also place boots over those P-lead terminals too, but this assures it stays out of the way entirely of that P-lead terminal.
Field wire at regulator - wiring run was long, so pulled the slack back through the firewall and re-terminated it with new ring connector at B&C regulator. Red cube wire terminated - into AMP 3 connector near battery. MAP hose fitting arrived and finished hose and installed.
