Fuel Line Fabrication started. Loopback line from filter to AFI pump. From fuel valve to filter. Tilting AFI pump inboard a bit will help the clearance problem on the positive terminal and also provide a better angle to avoid the L/R fuel valve inlets from the tank to clear the AFI output line to the firewall.
