Brief Description: Conical Bends at Aft/Center fuselage interface, ad
Clecoed F770 side skins and made bends at tailcone interface (i.e. the infamous conical bends).
Straightened accidental bending found in the longerons (counter to the sharp downward bend/twist area). Fit is now nearly perfect on the forward longeron to F770 skins.
Drilled 1-3/8" wiring holes for special grommet ordered earlier. Test fit the DSUB D-9's and they just fit through there, which will make this a good size for the mass of wing wiring.
