ROBERT'S WEB SITE
Date:  12-4-2015
Number of Hours:  6.00
Brief Description:  ER Tank Misc.
Nutplates and doublers riveted for inboard lower mounts - needed to do this as there is no means of nut access once tanks are installed and not enough flex in mount to slide out. This is due to the thickness of the weld of the end cap of the ER tank Outboard mounts - final placement and drilled mounts and ribs for clecos - #12. Riveted inboard fuel pump doubler plates.
