Brief Description: Fuel Pick ups/anti-rotation brackets and IB Cap se
Positioned fuel pick ups and drilled anti-rotation brackets. Installed AN fuel pick up bulkhead fitting to cover plate, riveted in anti-rotation brackets with sealant and encapsulated all areas. Inboard cap sender wires and BNC wire installed to inboard capacitance sender plates. Encapsulated in sealant. Checked continuity to ensure continuity between plates and middle BNC connector and confirmed zero continuity between sender plates and center BNC connector and tank structure. Confirmed continuity between BNC ground and fuel tank structure. Continuity checks performed on both tanks. Painted Z-brackets, covered all faying surfaces and surfaces that will have sealant. Cleaned baffles.
