Brief Description: New headliner kit and oil leak.
Took latest shipment from SkyTek to hangar, sorted out old pieces and new, Stowed away all pieces that will not be used. Compared headliners themselves. See photo, new headliner on bottom,. wider fabric at aft end is supposed to cover window area.
Removed felt from left side air vent, applied a heavier felt to make a better seal.
Once again tried to find oil leak. found it wet around oil quickdrin. Atbthe time of the first oil change I will try to find a better fitting O ring, and if not I will replace the quickdrain with a solid plug The baffle under the crankcase will also be loosen to the point of gaining access to the vacuum pump port cover.
