My Airplane Projects
Date: 10-14-2020
Number of Hours: 0.00
Brief Description: Oil leak and baggage area upholstery
Researched generator parts availability. Spruce seems to have everything we would need including oil seal, if we should need it.
Checked FWF for oil, it was dry. Pulled outside and did a 15-minute engine run, raised oil temp to about 100F. Pulled back into hangar and careful inspection showed no oil. Went to lunch, inspected again, no oil. Put electric heater and blanket on engine for two hours, still dry as a bone. Did I actually fix the problem when I tightened a few nuts a few days ago, or is the evil oil leak gremlin just laying back and ready to strike again?
Finished fitting baggage area cross-brace, clecoed in place, checked fit of upholstery. Removed all and on bench matched snap locations, drilled holes, and installed the provided snap studs. Then discovered the snap studs AirTex sent appear to be the wrong size. Grrrr. Will call them today. Am going to be really pissed if all the holes I drilled are too big.
