My Airplane Projects
Date: 10-13-2020
Number of Hours: 0.00
Brief Description: Oil leak and fuselage cross brace.
Checked FWF for any evidence of oil leaking since engine was cleaned yesterday. Noted a drop of oil clinging to bottom of generator. Does NOT seem to be coming from area where generator mates to accessory case, indicating a possible bad oil seal on shaft, allowing oil to migrate into generator housing. Cleaned the area, will check again tomorrow, then do an engine run and check again. If suspicions are confirmed the left mag and generator will have to be removed, and the generator disassembled and repaired.
Removed old baggage area cross-brace. It was clearly not an original factory part and was mounted below the fuselage stringers instead of on top as depicted in the IPC, and as required to match up to the new AirTex interior. Measured, cut, and drilled new cross-brace. Next steps are to attach the vertical headliner supports, dry fit the assembly, and test install the AirTex 3-sided upholstery for fit, then install mounting snaps to match the preinstalled parts on the rear curtain.
