Eds Vans RV-6A/7A Web Site
Date:  9-27-2008
Number of Hours:  0.00
Brief Description:  Wing Storage Cradle, Part 1.
After the top skins go on it's tiem to but your wings in a cradle.
This design is a modification of the design found at
http://www.ch601.org/tools/Wing%20Stand/wing_stand.htm
Check it out. You may have different midifications.
Image 1 shows the drawing and list of materials.
2 86" 2x4, top/bot horizontal cross members.
2 41" 2x4, left/right vertical members.
2 30" 2x4, left/right horizontal base members.
1 26" 2/4, horizontal, wing spar support.
2 18" 2x4, vertical, leading edge carpet supports.
1 6" 2x4, wing spar support spacer.
12 8"x8" ply-wood triangles
3 16"x8 ply-wood triangles
I also put rubber swivel casters on the botton.
Abby drilled all the holes, I screwed in all the screws.
This was a fun project in that it didn't involve the plane.
Fun, in that it was work you could do without worring about messing up your plane.
The simple plan.
The simple plan.
Materials cut.
Materials cut.
Abby drills all the holes.
