So here we go for repositioning the new duct. I have it well to the left hand side just inboard of the Andair valve extension.
Well that was a minor issue. To go as far to the left as possible this meant a curve was needed in my new duct as you see in pic 1. That was a couple of cure cycles. If you have a close look at pic 2 you can see where the universal join exits the front seat hole. This just needed a little more room.
Pic 3 has my new duct in place. It goes right over where the valve selector plate screws has to go so thats why I went for nut plates. I am right next to the top outlet piece so thats as far as I could go. It worked out really well in the end as you will see. The duct later becomes part of the 'side wall'.
This is all a reminder that I'm getting to the pointy end of making all these modifications fit into the back area. Its all new ground and I haven't opened the plans for a couple of months now.
