Brief Description: Oil Heater 46 More Trap Door adjustments
The trap door received even more mods to get it sealing better. Corners were removed and bits of glass added. It's getting pretty good and still fits.
Meanwhile I started making stange ramps to it as you see in pic 2. Can you guess whats going on?
Pic 3 shows that I've had to put nutplates secured around the Andair valve hole. Why nutplates instead of just lock nuts? Well its the same reason as the Pic 2 transitions. Hmmmm
In place with new mods
Difficult transitions
Nutplates to hole the Andair cover on the pilot side
