Brief Description: Primed Elevator Skins/Stiffeners
Spent the morning cleaning the stiffeners and inner elevator skins with Alumi Prep. They were dry by the afternoon so I mixed up a batch of VariPrime, donned the usual safety protection and primed away. When I was finished I probably had enough primer left over to do one more stiffener. Lucky or good - you be the judge :)
Later that evening the primer was dry so I back-riveted the stiffeners to the RH elevator skin. I'll rivet the LH elevator stiffeners and trim servo reinforcement plate tomorrow. I've had enough fun with stiffeners and need a change. Hi Louise!
Stiffners and skins prepped for priming
Right elevator stiffners riveted to skin after being primed
