Daves Web Site
Date:  10-17-2008
Number of Hours:  0.00
Brief Description:  HS Replacement Part Arrives
The replacement splice angle for the HS came in this afternoon so I removed the material per the plans and rounded the ends. Then I put them in the vice and bent the outboard flanges to 6 degrees. This went much quicker since I had ALREADY done this before on the piece I messed up.
Material to remove on the splice angle
Ready to put the 6 degree bend on the end flanges
6 degrees
6 degrees
