Got a lot done today. Started by fluting and deburring all of the VS ribs. Then I assembled them to the front and rear spars with clecos. Then I final drilled all of the hinge plates to the rear spar and drilled all of the ribs. Then I placed the VS skin over the VS frame and cleco'd every 2nd or 3rd hole. Match drilled all of the open holes, moved the clecos and drilled the remaining holes. Finally, something that looks like part of an airplane!
