Brief Description: New ACK ELT and NAV/STROBE wiring
18AWG shielded wire came through the spar from the VPX and needed a bus bar to connect each wing to the main wire. The shield is the ground and a blue power wire goes to NAV lights and a white power wire goes to Strobe lights. The AeroLED Pulsar NSP wingtip lights fulfill Nav,Strobe, and Position light requirements from one unit in each wingtip. Also, I replaced the old Ameriking-450 basic ELT with the newer ACK-E-04 406mhz GPS ELT. Had to add an additional angle support due to the new ELT being 1/2 the size. Still need run 12V to it, plus branch a GPS feed into it from my left wing Byonics APRS transmitter/GPS antenna. The new ELT antenna is stronger than the original one as well. Its mounted in the co-pilot corner behind the roll bar and follows the roll bar curve for its entire length.
3 bus bar jumpers allow sharing of the 3 wire sets on the bus bar.
