Routed the 1/4 inch brake lines from the parking brake connection on the firewall, to each side and along the floor to exit beneath the landing gear bracket. I will cushion the lines with sections of 1/4 ID flexible tubing secured to the fuselage. A 90 degree bulkhead fitting was used to change direction from horizontal to vertical out the bottom of the fuselage just in front of the landing gear. Temporary stub fittings coming out of the fuselage bottom keep unwanted things out of the lines while I continue making more brake lines.
Copilot side line almost done fabricating.
Temporarily capped the lines coming out fuselage bottom.
Parking brake connection. Brake pedal lines on top. Brake caliper lines out the bottom.
