Brief Description: Run Alternate Static Line Forward
Running the red static line forward to a panel-mounted alternate static switch required passing through the F605 and F604 bulkheads. Previously (years ago), Vans ok'd a small hole with no bushing. No bushing because the static tubing is resilient and with a 1/4 inch hole up high on the bulkheads, the bulkheads hold the line nice and tight. Its the same method I saw in 27 years of RVator publication too. Feeding the tubing through was no picnic but it worked out great. It connects to the panel ALT Static switch as well as to a Tee back where it branches off to the ADAHRS behind the baggage compartment.
Bringing the alternate static line forward to the panel.
Vans previously approved a 1/4 in hole through the top of the F605 and F604 bulkhead without bushing.
Connected to the Alt Static switch fitting from Steins.
