Wendells RV-6A
Date:  10-11-2023
Manual Reference:  Prep for Start
Brief Description:  Getting ready for engine start
Cleaned the fuel injection servo of stored dust. Tightened and secured the alternator with safety wire. Remounted the intake snorkel plus gasket and safety wired the bolts. Drained all the preservative oil and filled with Aeroshell W100 Plus (50W). This is a 600 hour engine. After replacing the lycoming sump with the Superior Cold Air Induction Sump, the Oil dipstick quantity markings were off by about 1 quart. I had trimmed off a little of the bottom of the dipstick to fully seat the dip stick in the new sump so I had to recalibrate the oil level markings as I filled the sump one quart at a time up to 7 quarts. I will re-stamp the dipstick at the correct volume marks
Before Start To Do's.
Time left mag.
Clean out fuel injectors and injector lines.
Pre lube engine.
Connect Starter Wire.
Remove dehydrator plugs and install all spark plugs.
Replace electric boost pump.
Snorkel final attach and safety wired.
Alternator correctly tensioned and safety wired.
Quart #7 being filled.
