Bent some 3/8 fuel line to make the drain line for the sniffle valve. It exits inbetween the two exhaust pipes and is coupled to the sniffle valve by use of rubber 3/8 fuel line and clamps. Also clamped it to engine mount very close to exit area for stability.
Easy routing with this Superior cold air induction sump.
3/8 rubber fuel line couples aluminum drain line to sniffle valve.
Exit area secured with adel clamps to engine mount.
