Brief Description: Added fittings to mechanical fuel pump
Old drain line was replaced with the standard Vans supplied drain line on the mechanical pump, facing 90 degrees down. Also, the pump outlet fitting was removed and I attached the Vans outlet. The red plug is where the fuel pressure line branches off the pump to the pressure reader mounted on the firewall.
Engine is on an engine stand with threaded rod and galv pipe at dynafocal angles.
Fuel pressure line goes where red cap is. Drain line clamps on copper fitting.
