Wendells RV-6A
Date:  1-3-2024
Manual Reference:  Add Antenna
Brief Description:  Add Belly Antenna for GTN750 Com
This last antenna installation is for my GTN750 Com. I have an SL40 on a topside antenna behind the tip up canopy rear window. It is primarily for ground operations, although either top or bottom should work fine for ground and/or air communications. This last install is positioned on the belly, just forward of the main spar on the pilot's side. I am using a RAMI AV17 bent antenna running parallel to the lower fuselage for ground clearance. Its a simple install using their template. RG400 antenna cable will be used like the other 5 antennas. (1 GTN750 Com, 1 GTN750 NAV, 1 GTN750 GPS, 1 SL40 Com, 1 Dynon ADSB, 1 Dynon Transponder.) I also have ELT antenna inside the rear window, a Dynon GPS antenna under the cowl, and an APRS transmitting and APRS GPS antenna out in the left wingtip. Thats 10 antennas. I think thats about it. Still looking for the GTN750 antenna BNC connector. Its somewhere here.
Template made for easy drilling.
interior backing plate plus exterior rubber mounting pad and Antenna all connectedl
Bent antenna runs parallel to fuselage to keep it out of my way.
