Wendells RV-6A
Date:  11-16-2023
Manual Reference:  Add CO Detector
Brief Description:  Add Guardian CO Detector to Panel
GuardianAvionics Carbon Monoxide Detector has model 353-101 basic panel mount detector with audible alarm plus visual panel light and test button. I came across an 8 year old unit which needed to be returned to the factory due to a 7 year expected life of the detector mechanism. It was too old to recalibrate and the factory offers $100 off retail for a new one if you return the core. So here it is, Installed and tested and it works great. I'm getting down to final few VPX power pins and I may consider using one to power a behind-the-panel electrical bus for 4 or 5 minor powered devices, like defrost fans, panel LED lights, etc.
Located the basic unit on the copilot side above the Skyview HDX.
Secondary alarm light mounted in front of Pilot above that HDX.
