Wendells RV-6A
Date:  5-13-2023
Manual Reference:  Hinge Wire Covers
Brief Description:  Finish cutouts for the Hinge Wire Covers
I plan on using a tab with a drilled hole on the forward end of one hinge wire to catch the upper machine screw as it is tightened into the nutplate. This will hold it in place. There is nowhere for the hinge wire to drift off to with this cover plate and fiberglass backing. However, I still wanted it to catch a positive stop on that upper machine screw. The other side does not have a tab on the hinge wire. I shaped a 3 sided bend of the hinge wire end to form a shape that a screwdriver can enter and be used as a pull device to begin pulling the wire when the time comes to take it apart. It also nestles nicely behind the cover so no movement can happen.
Propped the actual cover in place to see how it lays.
The fiberglass layup inside will fill old opening.
Layup will be next.
Layup will be next.
