Wendells RV-6A
Date:  11-2-2020
Number of Hours:  5.00
Manual Reference:  Pitot AOA
Brief Description:  Connect Pitot/AOA lines to ADAHRS
There's no break in the pitot and AOA lines coming from the heated pitot into the aircraft and rearward to the primary ADAHRS connection. Rubber bushings support the lines through the bulkheads. I will secure and cushion them where they cross over the inside step tube. WDG4 clamps secure the lines midship near and clear of the elevator control tube before they rise to the ADAHRS. The backup ADAHRS is already plumbed and wired.
Through F605 rearward to ADAHRS
Through F606 then left, then up to ADAHRS
Blue AOA -White Pitot-Red Static connected to primary ADAHRS and backup ADAHRS
