Wendells RV-6A
Date:  3-25-2018
Number of Hours:  0.00
Manual Reference:  Wing Install
Brief Description:  Fit wings to fuselage 2nd of 4 times-2
Pulled right wing and began trimming the forward F605 strap. Even though the required trim is .200, I started with about .125 and put it back together. Sweep was reduced by 9/16 so it's still 7/16 or so forward from the plumb line. The trimmed F605 bar is again up against the wing rib. I didn't trim the aft F605 strap as it rides along the rear spar web until it hits a 470 rivet head. I think I'll have to trim that aft F605 too, but only by maybe 1/16. Going very slowly here. Need to remember 5/8 clearance from top, bottom, outer and inner ends of the three pieces that nest together here.
Aft F605 rides along the wing spar but a nearby rivet will come into play after trimming.
Here's what I got after trimming 1/8 off forward F605 bar.
