Brief Description: Trailing edge countersink part II
After reading builder forums and seeing what others have done, I realized that I could clecko into wood ok. I match drilled the holes in the wedge through to the wood with a #40 bit. Clekos then held the part on the wood very nicely. I simply drilled the countersinks again like before and ended up with a nice line of countersunk holes. If some were not even, that's ok. Although mine all ended up nice and the rivet went flush when dropped in the hole.
